Pete10p
Feb 22, 2018Aspirant
ReadyNAS 102 sending to 64.233.167.109
I have two ReadyNas 102's running 6.9.2 firmware. My home LAN is setup to drop all traffic from and to the internet to be dropped. According to my router’s logs, both 102's are continually at...
Feb 23, 2018Guru - Experienced User
Netgear does push hot-fixes that are installed silently on your NAS, though I didn't think they use google cloud servers for that.
If you intend to prevent all outbound internet traffic from the NAS, you could set a static address but deliberately use a non-existent gateway.
- mdgm-ntgrFeb 23, 2018NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
- mdgm-ntgrFeb 24, 2018NETGEAR Employee Retired
Looks like your system is having problems sending queued email alerts. I think that I.P. is associated with gmail.
Is your NAS behind a corporate firewall/proxy?
- Pete10pFeb 25, 2018Aspirant
My firewall is set to drop all inbound and outbound traffic from the two ReadyNas.
I have deleted the email alerts, but the router is still seeing attempts to send something from the ReadyNas. The ReadyNas log has one incidence of a failure to send an alert however the router is seeing constant outbound attempts from the ReadyNas approx. every 15 seconds.
