mannythetech
Mar 31, 2016Aspirant
readynas 102 serial number none0002000000 why!!!!!!
i got my readynas from ebay and it has the serial number in the back but on the readycloud web interface it says none0002000000. please help i want to fix this also i try to register it and it says se...
mannythetech
oh ok but can i still get plex and the other features to work or is the Box basically useless
Mar 31, 2016Guru - Experienced User
You can still use the box and install apps. But you can't get paid support (which frankly has always puzzled me).
