levy1983
Jun 30, 2017Aspirant
ReadyNAS 102 TFTP_REQ problem
Hi Everybody, I have a ReadyNAS102. I switched off my router and NAS for 8-10 days. Yesterday I switched on everything, but my NAS is not working. The power LED is blinking, but nothing else. I can'...
Jun 30, 2017Guru - Experienced User
One option is paid support at my.netgear.com (booting up the NAS into tech support mode). Ask about per-incident support.
If you have USB devices connected (including a UPS) try disconnecting them all and see if that makes any difference. (Likely won't, but worth a try). If that doesn't help, perhaps try the USB recovery again.
