levy1983
Jun 30, 2017Aspirant
ReadyNAS 102 TFTP_REQ problem
Hi Everybody, I have a ReadyNAS102. I switched off my router and NAS for 8-10 days. Yesterday I switched on everything, but my NAS is not working. The power LED is blinking, but nothing else. I can'...
levy1983
Thanks for your answer. No USB device, just an ethernet cable to the router. I updated the firmware few times with 3 different pendrive, 3 different fw version, but with the same result: "TFTP_REQ". If I do a factory reset with no drive or other drive, and I reboot it with original disks? Will this destroy my data?
Jun 30, 2017Guru - Experienced User
You can't do a factory reset with no drives in place. The reset does a factory install to the hard drives.
At this point you might need support's help (though the US holiday would slow that down).
Was there a reason you did a USB recovery to update the firmware?
- levy1983Jun 30, 2017Aspirant
Ok, but what will happen if I do factory reset with another drive, than reboot it with original disks?
First I tried "OS reinstall" from boot menu, but nothing happend and I thought firmware update could solve the problem.
I don't really understand the whole concept. If the OS/booting is not working, than all of my DATA will be gone? Or what are the benefits of X-RAID arrays and two drives in this situation? How can I access to my data? Paid support is the only solution?
- StephenBJul 01, 2017Guru - Experienced User
If it works, the system is installed on the new drive, which accomplishes nothing. If it fails, that might provide some useful information on where the problem lies.
In general RAID is a good thing, but not enough to protect your data. You still need at least one backup on another device.
But I don't think your data is gone - though of course until the system can be booted there's no way to tell. I believe your system's flash memory is either corrupted or failed.
