gavpool
Sep 19, 2013Aspirant
ReadyNAS 104 - Can't connect to admin
I'm not a hardware techie and I'm new to the forum, so please be gentle. I have a ReadyNAS 104 with a single Seagate 4tb drive. Not sure of the exact build but it was updated a month ago. Should be...
Sep 20, 2013Guru - Experienced User
I suggest netgear support. If you purchased within 90 days, you can use the phone option. Otherwise use support.netgear.com.
