gavpool
Sep 19, 2013Aspirant
ReadyNAS 104 - Can't connect to admin
I'm not a hardware techie and I'm new to the forum, so please be gentle. I have a ReadyNAS 104 with a single Seagate 4tb drive. Not sure of the exact build but it was updated a month ago. Should be...
Oct 22, 2013Guru - Experienced User
I don't think its a conflict, but you could attempt to connect with ssh, and see if that works. The normal port is 22.
You could then attempt to reset the admin password from the command line.
