gavpool
Sep 19, 2013Aspirant
ReadyNAS 104 - Can't connect to admin
I'm not a hardware techie and I'm new to the forum, so please be gentle. I have a ReadyNAS 104 with a single Seagate 4tb drive. Not sure of the exact build but it was updated a month ago. Should be...
dhlewis
Oct 22, 2013Aspirant
StephenB wrote: I don't think its a conflict, but you could attempt to connect with ssh, and see if that works. The normal port is 22.
You could then attempt to reset the admin password from the command line.
Thanks. I'll give that a shot. I'm a bit wary, though, as I know what the password is. (Unless it got hashed.) I'm thinking that'll allow me to confirm it's a known quantity. But, ya never know! It might jiggle an electron loose, and get me going again.
I'll try it remote, but, may not be able to get over there for a day or so, if I have to use the custom port.
Cheers!
