GuidoKato
Jul 08, 2020Tutor
ReadyNas 104 - stuck with error message 'boot from USB failed'
hi, my Nas which worked completley fine until now is suddenly (without any specific impact, but i believe there was a general power failure in the city) showing the message 'boot from USB failed'. ...
GuidoKato
Jul 11, 2020Tutor
Hi - thank you for your quick reply!
I had put the 6.10.3 on the usb drive initially. then the debug error message was shown. I have found only one previous version on the netgear site - 6.10.2., but also with this the same problem and the same error message - no idea how the raidar shows 6.2.4, as I didn't boot from the usb to this version and I was always doing the firmware updates on a regular base, so can't be that there was such an old firmware installed before the problem was arising...
any idea what i can do? or with which firmwares before 6.10.2 I can retry, and where i can obtain them?
thanks a million, Guido
mdgm
Jul 11, 2020Virtuoso
The mention of 6.2.4 is coming from the boot recovery files, not what's on the internal flash.
The code needed to do boot recovery doesn't tend to change a lot over time.
Entering the debug state indicates that USB Boot Recovery failed at some point.
