smst
Nov 21, 2015Aspirant
ReadyNAS 104 / APC Back-UPS BE550G/BE700G sanity check
Hi all, I'm looking for a sanity check before I order a UPS for my RN104. I'm looking at one of these APC models: http://www.amazon.co.uk/dp/B002RXED6A Not the 400 as it seems to not hav...
smst
Thanks for the reply Stephen. I'd seen that thread before but it wasn't clear to me whether it applied to the 104 (I don't really have a handle on what other RN models are similar to the 104, so I always end up looking for something model-specific). Is there a page somewhere explaining that? Would perhaps stop me asking some questions...
Since you've referenced it I'll infer that what works on the Pro and Duo will work on the 104, as far as UPS is concerned.
Cheers,
Steve
Nov 21, 2015Guru - Experienced User
I'm in the US and use cyberlink myself. My UPS work with pro, duo, RN102, and RN202.
So I think APC will work, but I haven't used it myself. I don't work for Netgear, so I don't have any inside info.
