wayneb14
Oct 12, 2017Aspirant
ReadyNAS 104 apache2.service
Hi, I;m having a problem my NAS sahres are still accessible but i cannot login to the web iterface , the blue light on front of unit is flashing. and the display says 'retry startup', if i then press...
GalacticaRaptor
Oct 14, 2017Aspirant
It appears I have the exact same problem as you on my RN314 device on firmware 6.8.1. Shares are all accessible but the web interface is down, and ReadyCloud app on Windows can't find my device.
Ran systemctl status apache2 and got the following output:
/# systemctl status apache2 ● apache2.service - The Apache HTTP Server Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Sat 2017-10-14 01:02:02 PDT; 58s ago Process: 5630 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=1/FAILURE) Process: 5526 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS) systemd[1]: Starting The Apache HTTP Server... apache2[5630]: [Sat Oct 14 01:02:02 2017] [warn] module auth_token_module is already loaded, skipping apache2[5630]: apache2: Syntax error on line 244 of /etc/apache2/apache2.conf: Syntax error on line 1 of /et c/apache2/mods-enabled/php5.load: Cannot load /usr/lib/apache2/modules/libphp5.so into server: /usr/lib/apache2/modules/libphp5.so: wrong ELF class: ELFCLASS32 systemd[1]: apache2.service: Control process exited, code=exited status=1 systemd[1]: Failed to start The Apache HTTP Server. systemd[1]: apache2.service: Unit entered failed state.
systemd[1]: apache2.service: Triggering OnFailure= dependencies. systemd[1]: apache2.service: Failed with result 'exit-code'.
Looks like apache2 is borked for me as well.
Anyone has ideas?
wayneb14
I've just done a factory reset and its now working spent ages trying different things.
OS Reinstall didnt work
