wayneb14
Oct 12, 2017Aspirant
ReadyNAS 104 apache2.service
Hi, I;m having a problem my NAS sahres are still accessible but i cannot login to the web iterface , the blue light on front of unit is flashing. and the display says 'retry startup', if i then press...
wayneb14
Oct 14, 2017Aspirant
I've just done a factory reset and its now working spent ages trying different things.
OS Reinstall didnt work
GalacticaRaptor
Doesn’t the Factory reset also wipe your data? Really trying to avoid having to do that... I tried the OS Reinstall to no avail as well.
- wayneb14Oct 14, 2017Aspirant
Yes, It will wipe data and set eveything back to default, but I tried OS Re-Insatll twice and lots of other things from lots of different posts, but nothing worked. I copied all my data to External Drives, it was the only way
- GalacticaRaptorOct 14, 2017Aspirant
