wayneb14
Oct 12, 2017Aspirant
ReadyNAS 104 apache2.service
Hi, I;m having a problem my NAS sahres are still accessible but i cannot login to the web iterface , the blue light on front of unit is flashing. and the display says 'retry startup', if i then press...
mdgm-ntgr
Oct 14, 2017NETGEAR Employee Retired
wayneb14 wrote:
I have tried removing apache2 and re-installing but no use.
It's not a good idea to try things like that without doing proper troubleshooting first.
Retry Startup would suggest an issue starting the management service (readynasd)
apache2 failing to load a php module would suggest a problem with an app's install of PHP, not a problem with apache.
wayneb14
Oct 15, 2017Aspirant
Hi, I spent hours going through various posts which didn't work, Initailly it had a probelm with the transmission app (fv-app transmission), so I removed and re-installed that, then it wen onto the apache2.service message, so retried re-installing apache, I pretty much re-installed everything in case of corruption, and also tried OS Reiinstall from boot menu which went through firmware update, but still went back to same message apache2.service. I was getting concerned about data loss with all the fiddling so ended up copying 4TB of data off the drives (Whilst i could still access) to exterrnal and went for the Factory Reset.
