brando56894
Dec 17, 2013Aspirant
ReadyNAS 104 Crashing Constantly
I know there's already a thread open about this but I tried those work arounds and they don't seem to really help me. I just bought the 104 about 5 days ago to store all of my drives so I can access m...
JMehring
Dec 17, 2013Apprentice
The higher the number for nice the nicer it is to the system, so 12 will be nicer than 10 hehe. So your setting was higher and better on resources. But, look at the values, ionice does not take a number. Look at my examples above.
My cousin got a ReadyNAS and was looking at the 104, but I recommended her to get the 314 since it has Intel processor and more memory. It is able to run all the apps you have so if you are able to return and afford a 314 that's the route I would go since I really do not think the lower end units are designed to do much more than be a NAS.
If you do end up getting a 314, please be aware of the threads stating you will have to do a factory reset when 6.1.5 comes out since there is a bug in the OS that freezes up system (not sure if maybe you already effected by this bug). Just saying that so you have good backups until everything is sorted out.
Good luck!!!
Good luck!!!
