RedwolfAntares
Mar 07, 2025Tutor
ReadyNAS 104 disk failure
Hello, I've got an old readyNAS 104 who was working like a charm. I've tried to recover a file in an old version and it goes bersek and freeze. Now my NAS is not working well when it starts. I ...
Mar 16, 2025Guru - Experienced User
RedwolfAntares wrote:
Which disks I should insert?
Disk 3 seems ok as I can start on him only.
The problem here is that you need at least 2 disks that are in the array in order to mount it.
That requires using disk 2+3 for booting in the NAS, which didn't start. The RAID assembled, but there were BTRFS errors in the log.
If that doesn't mount read-only, then the best option is to use RAID recovery software in a Windows PC (ReclaiMe or possibly UFS explorer).
Could you tell me how to start in read only mode?
See pages 28-29 here:
RedwolfAntares
Mar 16, 2025Tutor
Thx, I've managed to start in read only.
Nas is flashing data degraded but most data files are readable.
Backup in progress!
đ
