retosteffen
Jun 25, 2013Aspirant
readynas 104 dual-disk redundancy? Flex Raid and XRaid2
Hi, I have an old NV+ and was thinking about upgrading but was looking for a dual-disk redundant system. Sadly the website isn't particularly clear (or I'm not looking at the right pages). Does th...
mdgm-ntgr
Jun 25, 2013NETGEAR Employee Retired
You should be able to use RAID-6 but performance won't be very good. I would recommend getting the RN314, RN316 or RN516.
You should be able to switch to Flex-RAID (i.e. disable X-RAID), delete the volume, create a RAID-6 volume then switch back to X-RAID.
