retosteffen
Jun 25, 2013Aspirant
readynas 104 dual-disk redundancy? Flex Raid and XRaid2
Hi, I have an old NV+ and was thinking about upgrading but was looking for a dual-disk redundant system. Sadly the website isn't particularly clear (or I'm not looking at the right pages). Does th...
Jul 01, 2013Guru - Experienced User
With OS6 you can switch. The existing volume(s) are deleted, but the OS settings, add-ons, etc. are preserved.
TeknoJnky wrote:
mdgm wrote:
You should be able to switch to Flex-RAID (i.e. disable X-RAID), delete the volume, create a RAID-6 volume then switch back to X-RAID.
Whaaaatt??
unless os6 has changed this, you can't switch from flex-raid to x-raid modes or vice versa without factory defaulting again.
I haven't seen an option to switch w/o deleting volumes though, so I am a bit confused also.
