RoyEsmonde
Sep 24, 2022Aspirant
ReadyNAS 104: How to manage an attached and identified APC UPS
I’ve just purchased an APC UPS (APC Back-UPS BE850G2 (BE850G2-UK)) and connected the UPS ‘Data Port’ to the USB port on the back of my ‘ReadyNAS 104’ ( 6.10.7) using the supplied cable. My ReadyNAS ...
- Sep 24, 2022
RoyEsmonde wrote:
I’ve just purchased an APC UPS (APC Back-UPS BE850G2 (BE850G2-UK)) and connected the UPS ‘Data Port’ to the USB port on the back of my ‘ReadyNAS 104’ ( 6.10.7) using the supplied cable. My ReadyNAS gives me a message that a UPS has been detected (see attached screen grab). But I can’t see any further ‘UPS’ tab or places on my Admin page to manage this UPS.
There isn't much to manage - all I see on my own NAS is the abillity to set the NAS shutdown threshold (which defaults to "auto").
But navigate to the "power" tab in the web ui, and you'll see a UPS section. The APC UPS should be shown there, with a settings wheel.
Sep 24, 2022Guru - Experienced User
RoyEsmonde
Thank you very much, StephenB.
I was following a different online article which suggested the UPS would be seen under 'Settings'. I should have checked 'Power'. Great to know I do have 'Auto' and some other percentage options which I presume refer to UPS battery remaining.
- Nov 29, 2019Retired_Member
