Spanfan
Jun 03, 2020Tutor
ReadyNAS 104 problems
I have two problems. I'm running the latest firmware and don't see the option for Antivirus that used to be there. Has it been removed ir if not how do I turn it on? Secondly, for some reason when...
Jun 03, 2020Guru - Experienced User
Spanfan wrote:
I have two problems. I'm running the latest firmware and don't see the option for Antivirus that used to be there. Has it been removed or if not how do I turn it on?
It was removed a while ago. The RN104 no longer has enough memory to run it.
Spanfan wrote:
Secondly, for some reason when i access the NAS from my PC the screen is the normal size but everything on it is very small and barely readable see attached. How do I return it to normal size?
Looks like a browser issue to me. Check the zoom setting when you are browsing the admin page. Note that entering ctrl+ will increase the zoom level in most browsers (and cntl- will decrease it).
- SpanfanJun 03, 2020Tutor
Thanks, it was the browser. That's sorted. Shae about teh antivirus, that's why I've some of my NAS files have been infected with kupidon ransomware even though the PC is clear.
Is there any antivirus that will protect the NAS as Malwarebytes doesn't?
- SandsharkJun 03, 2020Sensei
Spanfan wrote:Shae about teh antivirus, that's why I've some of my NAS files have been infected with kupidon ransomware even though the PC is clear.
I am unaware of any virus that can actually infect the NAS. So some PC with access to the files must be infecting them. Malware Bytes should be taking care of that.
Some PC virus checkers can be configured to check a mounted share, but that can be very slow. In fact, on some, you have to expressly tell it not to if that's your desire.
I don't understand what has happened then. Nothing on the PC connected to the NAS is infected but video, photo and document files on the NAS are. Fortunately most of them are backups from the PC so I can just delete and do a fresh backup. It's just worrying that I don't; know how it happened.
