sunsparc
Mar 26, 2017Aspirant
ReadyNas 104 RAID 0 Failure - Can I re-establish RAID 0 between drives?
Good Morning - Ive had this readynas unit for about 3 years now and never any issues. This weekend it started acting strange and the windows computers using the shares started to have long wait time...
sunsparc
To add additional information, I SSH'd into the device and checked the dmesg..md127 is the raid mount point...Does this mean this can't be repaired??
[ 17.989481] BTRFS critical (device md127): corrupt leaf, slot offset bad: block=73203712,root=1, slot=232
[ 17.990383] BTRFS critical (device md127): corrupt leaf, slot offset bad: block=73203712,root=1, slot=232
[ 17.991115] BTRFS: Failed to read block groups: -5
[ 18.020868] BTRFS: open_ctree failed
mdgm-ntgr
Mar 26, 2017NETGEAR Employee Retired
Updating the firmware in a situation like this is not recommended unless you get professional advice from us that determines that it is.
Using RAID-0 is inherently risky. If a disk fails all RAID-0 volumes using that disk are lost.
Data recovery is much more likely to be successful if a redundant RAID level is used.
What are the SMART stats of your disks like?
- sunsparcMar 27, 2017Aspirant
Both disks in the array look good. When i do a btrfs check /mnt/md127 thats when I see the bad block. When trying to mount thats when the message in dmesg is generated..
- FramerVApr 02, 2017NETGEAR Employee Retired
Hi sunsparc,
Let me see if I can get some inputs from mdgm about this.
- sunsparcApr 02, 2017Aspirant
Thanks for your help! I ended up expanding my drives to 4 and doing a RAID5..losing everything in process, but had it all backed up to amazon glacier...
