Ruesch
Feb 26, 2021Aspirant
ReadyNAS 104 show error b+4b every morning
Every morning for the last two weeks my ReadyNAS 104 is stuck and displays an error message in the display. The error code is "b+4b". Any ideas why this happens? What can I do to fix this problem? ...
Sandshark
Feb 26, 2021Sensei
Is there an overnight task, like a backup job, that might be triggering it? If so, can you disable it for one night and see it that is the trigger?
Ruesch
Mar 01, 2021Aspirant
Sorry, I have to correct myself. The error message is: do_exit+4b4
- StephenBMar 01, 2021Guru - Experienced User
That makes more sense, but doesn't change the next steps.
Something running in the NAS is crashing, and you need to figure out what that something is. Downloading the log zip and looking in the various logs for the crash might help. Systematically disabling services/apps might also help rule things out.
