AFlesher
Oct 24, 2022Aspirant
ReadyNAS 104 System Volume Root Storage 98%
I have received the following alert message:- System volume root's usage is 98%. This condition should not occur under normal conditions. Contact technical support. Anyone have any advice? ...
AFlesher
Nov 01, 2022Aspirant
Thank you. I looked through some other similar discussions and I seem to have resolved the problem by deleting a number of Temp files form the root of the NAS. No further alert messages received since.
Nov 01, 2022Guru - Experienced User
Good. Normally the root is about 25% full - if you are substantially over that, then you might want to analyze it some more.
