Grimleiv
Jan 06, 2018Tutor
ReadyNas 104 total Capacity
Hi I used the RAID calculator, added 2x 10TB and 2X 3TB. Calculator says total cap then is Capacity:14.5 TiB Protection:9.09 TiB Unused:0 B Level:X-RAID (raid5) But after factory rese...
bedlam1
Jan 06, 2018Prodigy
Have you tried a reboot or two?
Have you got X-Raid enabled?
8.17 tiB is what you could expect using Flex-RAID Raid 5
- GrimleivJan 06, 2018Tutor
I use X-Raid and get 8.17 but calculator says i should get(It's still resync, but capacity will not change after resync? Did factory reset first):
