Grimleiv's avatar
Jan 06, 2018
ReadyNas 104 total Capacity
Hi   I used the RAID calculator, added 2x 10TB and 2X 3TB. Calculator says total cap then is    Capacity:14.5 TiB Protection:9.09 TiB Unused:0 B Level:X-RAID (raid5)   But after factory rese...
  • StephenB's avatar
    Jan 06, 2018
    bedlam1 wrote:
    See how it looks after the Resync then reboot
    Yes.  Vertical expansion happens in a second stage, so after the reboot the capacity should increase.
ProSupport for Business
