JordanThompson
Apr 18, 2016Aspirant
ReadyNas 104 with two 2TB drives cannot recognize 4TB drive via eSATA or USB (front or back)
Hi all, I have a ReadyNAS 104 (100 with 4 bays). It currently has two 2TB drives in it in a XRAID. They are both synchronized. I want to use a 4TB drive connected to a Vantec NexStar (connect...
mdgm-ntgr
Apr 18, 2016NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig)
- JordanThompsonApr 19, 2016Aspirant
I sent the logs.
thanks very much for your help
- mdgm-ntgrApr 19, 2016NETGEAR Employee Retired
Thanks for the logs.
Was the disk connected to the NAS at the time you downloaded the logs and if so to which port?
The disk was not connected when I pulled the logs, but I tried the two USB ports in the back as well as the eSATA so you should see that. I also tried a 500GB drive thinking that the limitation was with the Vantec NexStar (which it turns out is not the problem as I was able to see and format the 4TB drive in the NexStar when it was connected to my computer) so you should see that also.
