JordanThompson
Apr 18, 2016Aspirant
ReadyNas 104 with two 2TB drives cannot recognize 4TB drive via eSATA or USB (front or back)
Hi all, I have a ReadyNAS 104 (100 with 4 bays). It currently has two 2TB drives in it in a XRAID. They are both synchronized. I want to use a 4TB drive connected to a Vantec NexStar (connect...
JordanThompson
Apr 19, 2016Aspirant
I sent the logs.
thanks very much for your help
mdgm-ntgr
Apr 19, 2016NETGEAR Employee Retired
Thanks for the logs.
Was the disk connected to the NAS at the time you downloaded the logs and if so to which port?
- JordanThompsonApr 19, 2016Aspirant
The disk was not connected when I pulled the logs, but I tried the two USB ports in the back as well as the eSATA so you should see that. I also tried a 500GB drive thinking that the limitation was with the Vantec NexStar (which it turns out is not the problem as I was able to see and format the 4TB drive in the NexStar when it was connected to my computer) so you should see that also.
- mdgm-ntgrApr 19, 2016NETGEAR Employee Retired
The logs are not as useful if the USB/eSATA disk is not connected at the time you download the logs. Please connect the USB disk and download the logs whilst it is connected and send those in.
- JordanThompsonApr 20, 2016Aspirant
I emailed you four logs that were dumpted while the backup drive was in the two back and one front USB ports as well as in the eSATA port.
