Danielsc87
Jan 03, 2021Aspirant
ReadyNas 104
Hello,, Im Trying to get FTPS working, it works no issues with internal IP address but deom an external DNS it comes up with this error, Port 21 is open, on my router and forwarded to the c...
Marc_V
Jan 03, 2021NETGEAR Employee Retired
Welcome to the Community!
When not using FTPS is the connection successful? Have you also tried changing settings on FileZilla under Site Manager?
Disabling any security software helped? Are you using explicit FTP? how about trying to use plain FTP as encryption?
- Danielsc87Jan 03, 2021AspirantHello.
Yes it is successful.
Yes tried all different settings and it doesn't work.
It made no difference
Yes I am
What do you mean by this. How does plain with encryption get set up. From what I could see the only secure connect is FTPS- rn_enthusiastJan 03, 2021Virtuoso
You need to also forward the passive ports. It is not enough with just port 21.
I suggest you limit the passive ports to a range equal to the amount of users you expect at a time. So if you expect 10 concurrent users/sessions maximum then set the port range to, for example, 60000 - 60010.
These ports also need to be forwarded to the NAS, from your router.
That is why it works with internal IP, but not external IP for you.
- StephenBJan 03, 2021Guru - Experienced User
Agreed, that is the problem here.
I usually recommend 4 ports per simultaneous connection, partly because some clients can use more than one data connection at a time, and partly because if the session drops it can take a little time for the server to close it.
The recommended range for dynamic/private ports is 49152-65535 (and of course 60000-60010 is within this range).
Masquerading can also come into play with some FTP clients. FileZilla is one that doesn't need masquerading set. If your particular client does need it, you should set the masquerade in the NAS to be your router's ddns name. Note that usually will prevent you from using FTP to access your NAS on your local network.
