HermanS
Nov 01, 2023Aspirant
ReadyNas 104
Still stuck on Admin login after firmware update, could I get some advise/help / solution please thank u
- Nov 09, 2023Hi Stephen
Backup of data is made... I reset the nas to factory settings yesterday (Wednesday) and it is stil running...
It says on the display Resync data:.. % see screenshot.
Am waiting to let it finish... Once finished I'll try to accès it... I keep u posted
Nov 01, 2023Guru - Experienced User
Did you try rebooting the NAS?
What was the firmware before the update, and what were you updating to? I'm asking because there are some intermediate updates needed if the firmware on the NAS was very old.
HermanS
Nov 02, 2023Aspirant
Yes, i shut it down, restarted it a few times, no effect. i was updating firmware ...
- HermanSNov 02, 2023Aspirant
actual firmware version is 6.7.5 ... thats when it all started
- SandsharkNov 02, 2023Sensei
It is important to know what you were updating from, as there are a couple of intermediate steps that have to be done if you are updating from old enough software.
Have you tried removing the drives to see what RAIDar reports then?
Hi sir, what do u mean by removing the drivers ... i cant acces it on my network, i see it but cant log in ...
