PSXman
Mar 24, 2025Aspirant
ReadyNas 104
ReadyNas 104 I have an issue when I went to install Zerotier this time on my latest NAS I accidently dis apt-get update & upgrade now I have no access to the readynas admin web interface. I ...
PSXman
Mar 25, 2025Aspirant
I've replaced the drive and factory reset and its back to normal but am having issues with the install of zerotier even though I've done it before on another 104 I own and it works fine
Mar 25, 2025Guru - Experienced User
Have you looked into the error on the https method being missing?
- PSXmanMar 25, 2025Aspirant
Cant find anything on it ive got down to this now
root@KROWTEN-SAN3:/data/temp# apt install ./zerotier-one_1.6.6_armhf.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'zerotier-one:armhf' instead of './zerotier-one_1.6.6_armhf.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:The following packages have unmet dependencies:
zerotier-one:armhf : Depends: iproute2:armhf but it is not installable
Depends: libstdc++6:armhf but it is not installable
E: Unable to correct problems, you have held broken packages.
root@KROWTEN-SAN3:/data/temp# ^C
root@KROWTEN-SAN3:/data/temp#- StephenBMar 25, 2025Guru - Experienced User
Was your other NAS also an arm platform? Or was it x86?
Looking at this thread, I am seeing that folks running on Arm could install 1.6.0 armh, but not 1.6.6.
Later on (post 107), Sandshark says 1.8.4 could be installed on armhf. I confirmed that in post 126. I also found that if I first installed openssl, I could install 1.87 on arm (post 128)
But this is not a package I use myself, so I haven't played with it since 2023.
Original Nas
root@KROWTEN-SAN2:/# hostnamectl
Static hostname: KROWTEN-SAN2
Icon name: computer
Machine ID: 3933cf956ff640bfa0fcc32b1473cb27
Boot ID: 6fd14a17e42e42098aa206a91a27dd53
Operating System: ReadyNASOS 6.10.9
Kernel: Linux 4.4.218.armada.1
Architecture: arm
root@KROWTEN-SAN3:/data/temp# hostnamectl
Static hostname: KROWTEN-SAN3
Icon name: computer
Machine ID: 6fbd90d31a3b408896f499248959f132
Boot ID: a07ae3539b824a2eac5da2e75308307c
Architecture: arm
root@KROWTEN-SAN3:/data/temp#Same am I trying to install the wrong version ?
