mrjoltcola
Nov 16, 2009Aspirant
ReadyNAS 1100 Unsatisfactory
I only recently learned how it felt to configure my ReadyNAS 1100's, because previously my sys-admin had been the one doing the work. We invested in 2 ReadyNAS 1100 units a couple of years ago. One...
mdgm-ntgr
Nov 16, 2009NETGEAR Employee Retired
1) Ok. That is an issue. In most cases you should only have to do initial setup once, so it's not too big a deal.
2) What version of RAIDar are you using? 4.1.6 can have some issues. Try the 4.1.7 beta. Alternatively, your disk could be bad. faq.php#How_can_I_verify_that_my_disk_is_bad%3F
3) Same as 2.
If you insert one drive and then factory default, drives you add subsequently if they've been used before will need to be added while the NAS is turned on so they are properly initialised.
3) Same as 2.
