mrjoltcola
Nov 16, 2009Aspirant
ReadyNAS 1100 Unsatisfactory
I only recently learned how it felt to configure my ReadyNAS 1100's, because previously my sys-admin had been the one doing the work. We invested in 2 ReadyNAS 1100 units a couple of years ago. One...
axxiris
Oct 12, 2011Aspirant
Hi,
We experienced the same problem.
Typing DELETE VOLUME in the confirmation dialog box was followed by the 'Volume delete aborted' message.
In our case we were using a RND4000 having local language set to dutch (Frontview).
We found out that the Netgear firmware developers possibly translated the 'DELETE VOLUME' confirmation string to the local language.
So, even when you are asked to type 'DELETE VOLUME', you have to type the translated string instead.
In our case it proved that using the wording of the 'Delete volume' button caption (the button that initiated the volume delete action) in capitals, was accepted as confirmation string. The caption of this button is translated.
That is, we typed 'VOLUME VERWIJDEREN' instead of 'DELETE VOLUME''.
Worked like a charm.
Hope this works for you too.
