dlovan's avatar
dlovan
Readynas 1500 No Access on normal mode
Hello Everyone  my department got an Readynas 1500 which is not working properly  and i tried many ways to fix it but still cant get access to it   the problem is it will only get IP address on ...
  • StephenB's avatar
    Apr 04, 2024
    dlovan wrote:
    the problem is
    it will only get IP address on TECH Support and Formatting mode
    On normal mode it doesn't get IP add and Raidar can't locate it
    I did
    * Factory Reset
    * OS Re-Installing
    Try powering down, and remove the disks (labeling by slot as you remove them).  Then power up, and see if RAIDar finds it (reporting diskless status).  If it does, then the problem is likely with the disks.
    If it does respond diskless, then try booting up with a single blank (unformatted) disk, and see if that works normally.  IF it does, then I suggest testing the production disks with vendor tools in a Windows PC (or just replacing them).
    FWIW, if your Factory Reset was successful, then the production disks would have been reformatted.
ProSupport for Business
