jameswalmsley
Feb 17, 2015Aspirant
ReadyNAS 200 series
Hi, I'm really keen to get a readynas 200 series. It said that the device would be available at the end of January, its still "coming soon". Is there any information regarding when it might be gen...
jameswalmsley
Apr 15, 2015Aspirant
giulianoz wrote:
how long does it take to rebuild the array ? can you tell how much was the rn204 ?
thanks
Just to update, looked back in the logs, and saw it took 12 hours to rebuild the raid.
I have 2 6TB WD drives currently installed.
Is that good or bad? It seems like a reasonable speed to me.
So far I'm quite impressed with the 204. Its quite zippy, and linux command line apps are zippy enough.
I currently have it running:
* DHCP server
* DNS server
* Print Server
* OneDrive-d
* Transmission
* Plex
Doesn't seem to slow down from running all that stuff so far, and memory usage remains low.
The onedrive-d daemon seems to create a lot of disk activity which I'm currently investigating but its great.
Current issues:
ReadyDLNA seems to disconnect with samsung smartTV after a while. Not sure why. Plex is simply amazing, although my girlfriend claims it disconnected. I have to see that happen.
