jameswalmsley
Feb 17, 2015Aspirant
ReadyNAS 200 series
Hi, I'm really keen to get a readynas 200 series. It said that the device would be available at the end of January, its still "coming soon". Is there any information regarding when it might be gen...
Apr 16, 2015Guru - Experienced User
I installed plex from the normal netgear applist. FWIW, post install the RN202 locked up for a few hours (even ping failed). I had to pull the plug and reinsert it. The library is building now.
mdgm wrote: Transcoding is not available.
SD transcoding seems to be working! XVID AVIs on my RN102 will not play with plex on my iPad. However, the same files will play from the RN202.
There's no HD content in the library at this point, so I have no way to try that right now.
