nbhatt_14
Apr 21, 2016Aspirant
ReadyNas 202 - Withdrawing mDNS address records / Withdrawing LLMNR address records etc...
Hi, I've noticed recently my ReadyNas 202 has been "playing up". Normally I'd expect the activity light to blink away if its carrying out a back up or in use. However just recently, I've see...
- Apr 22, 2016
If you have both cables connected w/o any bond configured, then it makes sense that you will see a duplicate host name. The system is likely detecting its own broadcast advertisement on the other NIC.
I suggest disconnecting one of the cables, just to see if the problem disappears. If it does, then you can reconnect the cable, and set up a suitable bond (LACP with a managed switch or an R8500, ALB or TLB with an unmanaged switch).
nbhatt_14
Apr 22, 2016Aspirant
Hi StephenB,
I do have both ethernet ports connected. I've had it set up like this from day one, but never encountered any issues.
Apr 22, 2016Guru - Experienced User
