Retired_Member
Apr 03, 2016Readynas 202 and recommended UPS?
I am to buy two Readynas 202 and I want a ups to them. I prefered APC of some reason ;) Wich is working best for 202? I have an old ReadyNas Duo before and the APC ups communicate through serial...
- Apr 04, 2016
Hi bruse,
Check this ReadyNAS UPS community board to search which UPS was tested and will work perfectly with your system. Also, here's a helpful article you can look at in setting up a UPS with an OS 6 system.
Kind regards,
BrianL
NETGEAR Community Team
Retired_Member
Apr 04, 2016Thanks!
Any modell of APC you can recomend? Or some modell i DONT should buy?
BrianL2
Apr 04, 2016NETGEAR Employee Retired
Hi bruse,
Kind regards,
BrianL
