kansalravi
Dec 17, 2019Follower
ReadyNAS 204 - ERR: Used disks Check RAIDar
Getting error on display "Used Disks check RAIDar" for RN204 model.
Try all the options firware check,os reinstall nothing is working.
On hard disk check got error on hardisk 1.Don't know what to do.Replace or there is some other issue.
Also try to do factory reset but getting error " Cann't create RAID"
Please help what to do..
Attching error file
1 Reply
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
Was your NAS already configured before this happened? I would assume you have full backup of your Data when you performed Factory reset.
You may have to replace the disk that has errors before doing any other steps.Kindly try to format the drives on your PC using WD lifeguard or Seagate tools. Once done, try to initialize a Factory reset again.
HTH
Regards
