vinnynasoz
Jun 19, 2016Aspirant
ReadyNAS 204 - How to automatically connect to shared drive on startup?
Firmware: 6.5.0 I have installed the ReadyCloud Windows client on my PC. I can connect to my ReadyNAS shared drive without any problems as long as I click on the shared folder in the ReadyCloud W...
- Jun 22, 2016Did you try to the "manage network password" panel in Windows?
BrianL2
Jun 21, 2016NETGEAR Employee Retired
Hi vinnynasoz,
Can you confirm if the computer that you're using to map the drive is on the same network? If not, this is a normal behavior.
Kind regards,
BrianL
NETGEAR Community Team
- vinnynasozJun 21, 2016Aspirant
Yes. Same network and same Workgroup.
Why must I manually connect the drives (click on shared folder in ReadyCloud client) when my Windows 10 boots up? Does not make any sense to me.
