vinnynasoz
Jun 19, 2016Aspirant
ReadyNAS 204 - How to automatically connect to shared drive on startup?
Firmware: 6.5.0 I have installed the ReadyCloud Windows client on my PC. I can connect to my ReadyNAS shared drive without any problems as long as I click on the shared folder in the ReadyCloud W...
- Jun 22, 2016Did you try to the "manage network password" panel in Windows?
omicron_persei8
Jun 22, 2016Luminary
- vinnynasozJun 22, 2016Aspirant
No not yet. I will try it later this week.
I contacted support and they told me what I am experiencing is the expected behaviour.
Maybe you are right. The shared folder looks for my ReadyCloud credentials to authenticate me and the username and password are stored in the ReadyCloud client. The solution might be to add my ReadyCloud credentials to Windows directly.
- BrianL2Jun 22, 2016NETGEAR Employee Retired
Hi vinnynasoz,
Just update this thread once you're done testing it.
Kind regards,
BrianL
NETGEAR Community Team- vinnynasozJun 24, 2016Aspirant
I added my ReadyCloud username and password into Credential Manager -> Windows Credentials. Entered my ReadyNAS \\IP Address followed by my ReadyCloud username and password.
Restarted my PC and it automatically connected to my shared backup folders.
Thanks!
