Kardano
Mar 21, 2018Luminary
Readynas 204 n o admin page
RN204, FW 6.9.3 After installing app (phpsysadmin) from no web admin interface. Tried restart, no help. On ssh i get: root@PMNAS01:~# systemctl status apache2 â apache2.service - The Apache HTTP...
Kardano
Hello,
tied IE, Firefox, chrome. Cache cleared. No change.from SSH it seems that apache does not start. But i am not at that level to reepair it myself.
So thi is "someone help me" or i have to facory default this unit. :-(
Kardano
Marc_V
Mar 22, 2018NETGEAR Employee Retired
Hi Kardano,
Can you send me your logs through PM. You may also want to contact NETGEAR Support to be assisted right away.
Factory defaulting the unit should be your last resort, let's check your logs first as other options might be possible.
Regards
- KardanoMar 22, 2018Luminary
Hi Marc_V
now i see admin page.
installed apps has no icon.
but when i get to ssh i get this:
root@PMNAS01:~# systemctl status apache2 â apache2.service - The Apache HTTP Server Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Thu 2018-03-22 09:03:38 CET; 20min ago Process: 5777 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=1/FAILURE) Process: 5677 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS) Mar 22 09:03:38 PMNAS01 systemd[1]: Starting The Apache HTTP Server... Mar 22 09:03:38 PMNAS01 fvapps[5677]: WARNING: Excluding bad https config for app 'nastools-netdata' Mar 22 09:03:38 PMNAS01 fvapps[5677]: WARNING: Excluding bad https config for app 'smbplus' Mar 22 09:03:38 PMNAS01 apache2[5777]: apache2: Syntax error on line 244 of /etc/apache2/apache2.conf: Syntax error on line 2 of /etc/apache2/mod s-enabled/access_compat.load: Cannot load /usr/lib/apache2/modules/mod_access_compat.so into server: /usr/lib/apache2/modules/mod_access_compat.s o: cannot open shared object file: No such file or directory Mar 22 09:03:38 PMNAS01 systemd[1]: apache2.service: Control process exited, code=exited status=1 Mar 22 09:03:38 PMNAS01 systemd[1]: Failed to start The Apache HTTP Server. Mar 22 09:03:38 PMNAS01 systemd[1]: apache2.service: Unit entered failed state. Mar 22 09:03:38 PMNAS01 systemd[1]: apache2.service: Triggering OnFailure= dependencies. Mar 22 09:03:38 PMNAS01 systemd[1]: apache2.service: Failed with result 'exit-code'. root@PMNAS01:~#
- Marc_VMar 22, 2018NETGEAR Employee Retired
Hi Kardano
It seems that a package has been corrupted/broken.
I think you should remove the app you installed first, that might not be compatible with 6.9.3 or perhaps check for an update from the developer.
Is everything okay now? Hope this is resolved.
Regards
