realtek30
Aug 03, 2015Aspirant
ReadyNAS 204 or 314?
Hi, I am looking at buying a new ReadyNAS. I had a 104 a few years ago and it was so slow I ended up returning it as it was not suitable. I have since seen the 204 is avaiable and I wonde...
mdgm-ntgr
Aug 03, 2015NETGEAR Employee Retired
I would suggest that you disable bitrot protection and snapshots on the iSCSI LUN to be used with ESXi. VMs involve a lot of small writes and with lots of writes and CoW or snapshots (well snapshots use CoW at the point in time the snapshot is taken) you will quickly get a lot of fragmentation.
Not sure where you saw that the 204 would take larger disks than the 314. The 314 would be a better choice than the 204 for using high capacity disks. We have a compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641
We have a limitation on current firmware on the 204 where snapshots do not work on volumes > 16TB. This will be addressed in a future release. With 4x6TB disks you will get a RAID-5 volume > 16TB.
- StephenBAug 03, 2015Guru - Experienced User
I believe the OP meant that the 204 takes bigger disks than the 104. That's true because of the 16 TiB volume limit on the RN100 series.
Good to know, I hadn't seen that posted here.
- realtek30Aug 04, 2015Aspirant
Thansk All,
I read it here, the 204 Tech Specs state it takes a maximum of 24TB of disks.
The 314 Tech Specs says it takes a maximum of 16TB.
http://www.netgear.com/home/products/connected-storage/RN204.aspx#tab-techspecs
http://www.netgear.com/business/products/storage/readynas/RN31400.aspx#tab-techspecs
Are the specs wrong?
Thanks
- StephenBAug 04, 2015Guru - Experienced User
The RN314 spec is outdated. The PDF is correct: http://www.downloads.netgear.com/files/GDC/datasheet/en/RN300-RN500-RN700.pdf
When released, the largest available disks were 4 TB. Now larger disks are available and supported.
ok thanks Stephen!
I will look at the PDF instead.
