realtek30
Aug 03, 2015Aspirant
ReadyNAS 204 or 314?
Hi, I am looking at buying a new ReadyNAS. I had a 104 a few years ago and it was so slow I ended up returning it as it was not suitable. I have since seen the 204 is avaiable and I wonde...
realtek30
Aug 04, 2015Aspirant
Thansk All,
I read it here, the 204 Tech Specs state it takes a maximum of 24TB of disks.
The 314 Tech Specs says it takes a maximum of 16TB.
http://www.netgear.com/home/products/connected-storage/RN204.aspx#tab-techspecs
http://www.netgear.com/business/products/storage/readynas/RN31400.aspx#tab-techspecs
Are the specs wrong?
Thanks
Aug 04, 2015Guru - Experienced User
The RN314 spec is outdated. The PDF is correct: http://www.downloads.netgear.com/files/GDC/datasheet/en/RN300-RN500-RN700.pdf
When released, the largest available disks were 4 TB. Now larger disks are available and supported.
- realtek30Aug 04, 2015Aspirant
ok thanks Stephen!
I will look at the PDF instead.
