mmm1's avatar
mmm1
Follower
Aug 11, 2013
ReadyNas 2100 and 4TB Harddrives
Hi,
are there any experience with using 4 x 4TB Harddiscs with the ReadyNAS 2100? I'm thinking about an upgrade.
Thanx.
Markus
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Should work fine. Though NetGear can and will deny support if you choose disks outside the compatibility list.
    2100 v1 has similar Tolapai CPU to what is used in the NVX
    2100 v2 has same Intel Atom CPU as Pro 4
    Some but not too many rackmount users on the forum but plenty of desktop NAS users have found 4TB disks work fine for them.
    Welcome to the forum!
ProSupport for Business
