brhodgins
Jun 25, 2014Aspirant
ReadyNAS 2100 compatibility with 4TB drives?
Anyone? I don't see anything in the HCL for 4TB drives working with the 2100. I like the NAS, and don't want to retire it, but I'd like to give it a capacity upgrade. The WD 4TB SE drive (WD4000F...
bsteingraber
Apr 13, 2015Aspirant
brhodgins wrote: Anyone?
The WD 4TB SE drive (WD4000F9YZ) is in the HCL for the newer 21xx series units. Is there a limitation in the BIOS or OS that will prevent me from using these or have they just not been formally tested with the older unit?
Currently I have 2x 2TB and 2x 1TB drives, as I replaced failed 1TB with a 2TB in the XRAID.
Brad
Brad, did you ever try using the 4TB drives with your 2100? I am looking to also try...
