Mr__Bear's avatar
Mr__Bear
ReadyNAS 2100 Increasing Command Timeout on Disk 3
Hi...
We have a ReadyNAS 2100 with 4x2TB drives (Seagate ST32000644NS SN12) that has been in service for a couple of years. Disk 3 was replaced last year with a downright drive failure.
The first replacement drive from NETGEAR (Seagate ST2000NM0011 SN02) worked until a few days ago when the Command Timeout shot up to >50 in the span of 2 days.
Case# 19802848 was opened with Level 2 Support, while waiting for the replacement drive to arrive (that is another sorry story about poor packing/shipping by TraceLogix) I replaced the Disk 3 with another brand new spare Seagate ST2000NM0011 SN02. WIthin the first 8 hours of putting the drive in production, the Command Timeout increased from 0 to 8 again.
The initial 4 Command Timeout were raised immediately when I hot plug the new drive into Bay 3. The following errors started earlier at 07:09:36 mark below, it tried to recover with resetting the link and was able to get 3.0 Gbps. 5 minutes later the same error again and after a few more try it settled with a reduced 1.5 Gbps link and it has been "stable" for the last few hours while the array is being pounded on with read requests from a full backup. The ReadyNAS 2100 is connected to a Proliant DL165 G7 running Vmware ESXi 5.1 over a iSCSI VLAN round robin, the error messages below is when I reboot and restart both the server and NAS where 11 VMs totalling 1TB is size launched two minutes apart from the iSCSI volume on the NAS.
Nov 7 06:39:17 emboar kernel: ata5.00: configured for UDMA/133
Nov 7 06:39:17 emboar kernel: ata5: EH complete
Nov 7 06:39:57 emboar kernel: ata5: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 42
Nov 7 06:39:57 emboar kernel: ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 7 06:39:57 emboar kernel: ata5.00: ATA-8: ST2000NM0011, SN02, max UDMA/133
Nov 7 06:39:57 emboar kernel: ata5.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Nov 7 06:39:57 emboar kernel: ata5.00: configured for UDMA/133
Nov 7 06:39:57 emboar kernel: ata5: EH complete
====>Nov 7 07:09:36 emboar kernel: ata5.00: exception Emask 0x10 SAct 0x60005fef SErr 0x400100 action 0x6 frozen
Nov 7 07:09:36 emboar kernel: ata5.00: irq_stat 0x08000000, interface fatal error
Nov 7 07:09:36 emboar kernel: ata5: SError: { UnrecovData Handshk }
Nov 7 07:09:36 emboar kernel: ata5.00: failed command: WRITE FPDMA QUEUED
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/a0:00:48:4e:a2/01:00:13:00:00/40 tag 0 ncq 212992 out
Nov 7 07:09:36 emboar kernel: ata5.00: status: { DRDY }
Nov 7 07:09:36 emboar kernel: ata5.00: failed command: READ FPDMA QUEUED
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 60/08:08:e0:11:af/00:00:12:00:00/40 tag 1 ncq 4096 in
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:10:e8:4f:a2/04:00:13:00:00/40 tag 2 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:18:e8:57:a2/04:00:13:00:00/40 tag 3 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:28:e8:53:a2/04:00:13:00:00/40 tag 5 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:30:e8:5b:a2/04:00:13:00:00/40 tag 6 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:38:e8:5f:a2/04:00:13:00:00/40 tag 7 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:40:e8:63:a2/04:00:13:00:00/40 tag 8 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:48:e8:67:a2/04:00:13:00:00/40 tag 9 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:50:e8:6b:a2/04:00:13:00:00/40 tag 10 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:58:e8:6f:a2/04:00:13:00:00/40 tag 11 ncq 524288 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/60:60:e8:73:a2/03:00:13:00:00/40 tag 12 ncq 442368 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/00:70:48:4c:a2/02:00:13:00:00/40 tag 14 ncq 262144 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/f0:e8:e8:49:a2/01:00:13:00:00/40 tag 29 ncq 253952 out
Nov 7 07:09:36 emboar kernel: ata5.00: cmd 61/70:f0:d8:4b:a2/00:00:13:00:00/40 tag 30 ncq 57344 out
Nov 7 07:09:36 emboar kernel: ata5: hard resetting link
Nov 7 07:09:36 emboar kernel: ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Nov 7 07:09:36 emboar kernel: ata5.00: configured for UDMA/133
Nov 7 07:09:36 emboar kernel: ata5: EH complete
Nov 7 07:14:07 emboar kernel: ata5.00: exception Emask 0x10 SAct 0x7fffffff SErr 0x400100 action 0x6 frozen
Nov 7 07:14:07 emboar kernel: ata5.00: irq_stat 0x08000000, interface fatal error
Nov 7 07:14:07 emboar kernel: ata5: SError: { UnrecovData Handshk }
Nov 7 07:14:07 emboar kernel: ata5.00: failed command: READ FPDMA QUEUED
Nov 7 07:14:07 emboar kernel: ata5.00: cmd 60/20:00:18:c0:a2/00:00:12:00:00/40 tag 0 ncq 16384 in
Nov 7 07:14:07 emboar kernel: ata5.00: status: { DRDY }
I am waiting for Level 2 Support to get back to me but want to query the experts on the forum for some advise. Could it be the backplane itself going bad? Seems like 3rd drive in a row on the same Bay 3.
Any advise is greatly appreciated. Thanks!
1 Reply
  • Here is the portion of the log showing sata5 being downgraded to 1.5Gbps from 3.0Gbps -
    Nov 7 07:15:40 emboar kernel: ata5.00: status: { DRDY }
    Nov 7 07:15:40 emboar kernel: ata5.00: failed command: WRITE FPDMA QUEUED
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/90:50:50:91:a2/00:00:08:00:00/40 tag 10 ncq 73728 out
    Nov 7 07:15:40 emboar kernel: res 40/00:b0:c8:9c:a2/00:00:08:00:00/40 Emask 0x10 (ATA bus error)
    Nov 7 07:15:40 emboar kernel: ata5.00: failed command: READ FPDMA QUEUED
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 60/80:58:48:98:3d/00:00:04:00:00/40 tag 11 ncq 65536 in
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/40:60:48:9c:a2/00:00:08:00:00/40 tag 12 ncq 32768 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:68:b8:97:60/00:00:01:00:00/40 tag 13 ncq 4096 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/18:70:c8:97:a2/00:00:08:00:00/40 tag 14 ncq 12288 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/38:78:90:8d:a2/00:00:08:00:00/40 tag 15 ncq 28672 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:80:c8:90:a2/00:00:08:00:00/40 tag 16 ncq 4096 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:88:d0:90:a2/00:00:08:00:00/40 tag 17 ncq 4096 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/78:90:d8:90:a2/00:00:08:00:00/40 tag 18 ncq 61440 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/10:98:e0:91:a2/00:00:08:00:00/40 tag 19 ncq 8192 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/20:a0:c8:9b:a2/00:00:08:00:00/40 tag 20 ncq 16384 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/60:a8:e8:9b:a2/00:00:08:00:00/40 tag 21 ncq 49152 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/48:b0:c8:9c:a2/00:00:08:00:00/40 tag 22 ncq 36864 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/90:b8:00:8d:a2/00:00:08:00:00/40 tag 23 ncq 73728 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/18:c0:08:92:a2/00:00:08:00:00/40 tag 24 ncq 12288 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:c8:38:93:a2/00:00:08:00:00/40 tag 25 ncq 4096 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:d0:08:93:a2/00:00:08:00:00/40 tag 26 ncq 4096 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/28:d8:10:93:a2/00:00:08:00:00/40 tag 27 ncq 20480 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:e0:40:93:a2/00:00:08:00:00/40 tag 28 ncq 4096 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:e8:c8:90:60/00:00:01:00:00/40 tag 29 ncq 4096 out
    Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/28:f0:60:97:a2/00:00:08:00:00/40 tag 30 ncq 20480 out
    Nov 7 07:15:40 emboar kernel: ata5: hard resetting link
    Nov 7 07:15:40 emboar kernel: ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
    Nov 7 07:15:40 emboar kernel: ata5.00: configured for UDMA/133
    Nov 7 07:15:40 emboar kernel: ata5: EH complete
    Nov 7 07:16:08 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
    Nov 7 07:19:17 emboar RAIDiator: Detected increasing command timeouts on disk 3 [8, 7]
    Nov 7 07:19:17 emboar RAIDiator: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (35, 1, 13, 1, 1)
    Nov 7 07:21:03 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
    Nov 7 08:52:07 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
    Nov 7 09:04:54 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
    Nov 7 09:20:29 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
ProSupport for Business
