bsailer
Jan 07, 2024Tutor
ReadyNAS 212: Set-Up of OneDrive bidirectional sync fails
Hi guys, I´m trying to set up a sync between a directory in my local Netgear ReadyNAS 212 (firmware version 6.10.8 - the newest one) and MS OneDrive (free plan). Here's what I´m doing to achieve th...
Sandshark
Jan 11, 2024Sensei
Have you tried NAS to OneDrive only, just to see if that works? If it does, then try changing it to bi-directional after the files are uploaded.
bsailer
Jan 12, 2024Tutor
Hi Sandshark,
thanks for the suggestion. Unfortunately, regardless of the sync-direction I'm not even able to specify the cloud path (clicking on it to fill immediately opens the folder dialog that in turn raises the error message).
So it's not syncing that fails, but the creation of the session beforehand.
Best,
Benjamin
- SandsharkJan 12, 2024Sensei
That is odd. I previously had no OneDrive backup set up and went in and created one without a hitch. It sounds a bit like a credentials issue, but I don't understand how you'd even get that far if that was it.
