bsailer
Jan 07, 2024Tutor
ReadyNAS 212: Set-Up of OneDrive bidirectional sync fails
Hi guys, I´m trying to set up a sync between a directory in my local Netgear ReadyNAS 212 (firmware version 6.10.8 - the newest one) and MS OneDrive (free plan). Here's what I´m doing to achieve th...
hanplo
Jun 03, 2024Aspirant
I have the same problem. Do you have a solution for this problem....
Sandshark
Jun 04, 2024Sensei
hanplo, what model ReadyNAS do you have? I'm wondering if this may be a bug in the ARM version since I have no issue with the Intel version. I left the backup I created as a test going, and it's continued to function just fine.
- hanploJun 04, 2024AspirantI have the Netgear ReadyNAS 102
