Snowman8
Jan 24, 2020Tutor
ReadyNAS 212 won't upgrade or install apps! Help!
I have the ReadyNAS 212 with firmware 6.9.4 Hotfix 1. When I click "check for updates" it says a new version 6.10.2 is available, but when I click "Update". I get the error 6001010056. I have trie...
- Feb 01, 2020
Hi Snowman8,
The issue could be network related. There might be a network filter that is going on or something.
We are getting "hash sum" errors when trying to check for updates. We also tried downloading Plex and it is the same.
The NAS cannot successfully download the deb file from the server itself for whatever reason, but when we go to manually install it, we have to get dependencies and they have a similar problem. It is almost like network traffic being intercepted.
Snowman8
Jan 27, 2020Tutor
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 1.1G 2.5G 31% /
tmpfs 1009M 0 1009M 0% /dev/shm
tmpfs 1009M 6.8M 1003M 1% /run
tmpfs 505M 940K 504M 1% /run/lock
tmpfs 1009M 0 1009M 0% /sys/fs/cgroup
/dev/md127 5.5T 3.1T 2.4T 57% /data
/dev/md127 5.5T 3.1T 2.4T 57% /apps
/dev/md127 5.5T 3.1T 2.4T 57% /home
=== df -i ===
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 187946 228 187718 1% /dev
/dev/md0 1048576 12274 1036302 2% /
tmpfs 188827 1 188826 1% /dev/shm
tmpfs 188827 434 188393 1% /run
tmpfs 188827 21 188806 1% /run/lock
tmpfs 188827 9 188818 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /data
/dev/md127 0 0 0 - /apps
/dev/md127 0 0 0 - /home
JohnCM_S
Feb 01, 2020NETGEAR Employee Retired
Hi Snowman8,
- Snowman8Feb 01, 2020Tutor
A BIG thanks to JohnCM_S!! He narrowed the issue down to a network issue.
The NAS is connected to my Orbi router via two chained switches. After reading his message today indicating a possible network issue, I plugged the NAS into the the first switch skipping the second. I restarted the switch and it errored again. I rebooted the NAS and turned off anti-virus and it updated!!
I turned anti-virus back on. I tred to install the Plex server. It errored out. I turn off anti-virus and tried again with no success. I left the anti-virus off, rebooted and then I was able to install Plex server. All is working great!
