jarness17
Feb 19, 2020Aspirant
ReadyNas 2120 Syncing
Hi, We have a ReadyNas 2120 which twice over the last two months has randomly started running a sync and stating "The ReadyNas is currently syncing. During this process, the system is still acces...
Feb 20, 2020Guru - Experienced User
jarness17 wrote:
Wed Feb 19 2020 6:24:28 System: ReadyNASOS service or process was restarted.
Why did the above restart happen? Perhaps look at the full log zip file.
I believe that is what is triggering the resync.
Sandshark
Feb 20, 2020Sensei
One common reason is a drive error (often ATA error) that makes the NAS drop the drive from the array, then later pick it up as good and start the re-sync. I just replaced a drive for that exact same issue -- SMART shows 300+ ATA errors.
