Smoyle
Jan 29, 2024Follower
ReadyNAS 2120 v2 and NetaTalk
Good morning all, I have a ReadyNAS 2120 v2 running 6.5.0 firmware, everything is running fine but on a recent penetration test we had an alert advising us that NetaTalk is out of date and should be ...
Jan 30, 2024Guru - Experienced User
Smoyle wrote:
I have a ReadyNAS 2120 v2 running 6.5.0 firmware, everything is running fine but on a recent penetration test we had an alert advising us that NetaTalk is out of date and should be updated.
The issue is I can't find any reference to NetaTalk in the admin portal.
As schumaku says, NetaTalk is AFP. If it is enabled on your NAS, you can probably disable it, since current MacOS software supports SMB. Generally it is best practice to disable protocols you don't use.
6.5.0 firmware was released in May 2016, and there have been a lot of security updates made since then. 6.10.10 was just released, so it might be prudent to update to 6.10.9, and check back here in few weeks on whether anyone has found issues with 6.10.10. You will need to manually download and install it, as Netgear has apparently forgotten the NAS has a "check for updates" feature, and they have neglected to put the past two releases on their update server.
