AndrewBLQ
Feb 11, 2020Aspirant
ReadyNAS 2120 v2 performance degraded
I've been getting alerts from my ReadyNAS 2120 v2 saying the Volume is degraded, but there is nothing I can see that is causing the issue, and i've run a Defrag, a Scrub, a Disk Test and rebooted it ...
AndrewBLQ
Feb 12, 2020Aspirant
Thanks Marc_V
I have downloaded the full logs and I cannot see anything relating to a HDD failing. That screenshot and the alert emails are the only thing that is showing there is an issue, but it doesnt show me what disk is failing or why. Is there a specific log file I should be looking in?
Feb 12, 2020Guru - Experienced User
Start with mdstat.log. You can copy/paste it into a reply if you like. It will give you the status of each RAID group (including the OS partition and the swap partition).
Disk_info.log will give you smart stats for each disk. Of course system.log and kernel.log would generally also have any I/O errors for the disks.
